Grafana API to export grafana configuration
Is there any API endpoint for exporting Grafana configuration file ?
grafana.ini
I want to export it from a running Grana instance and then start a new Grafana instance in a container and pass it as a environment variable when I start the container.
GF_PATHS_CONFIG=/etc/grafana/grafana.ini
Thx
Hi @dejanu
Are you running self-hosted Grafana or Grafana cloud? If you are running your own instance, are there not other ways to retrieve that file and then pass it into a container?
Hi @anon70503803, self-hosted. Thx
could you perhaps scp the file instead?
