I am using grafana with docker installation.
How can I change the grafana.ini file inside the Portainer GUI (Container console)?
thx
Hello
and welcome to the forum, @gentleman
What are you trying to change in the config?
You can pass in configuration changes when you start the container like this:
docker run -d \
-e GF_DEFAULT_APP_MODE=development \
-p 3000:3000 \
-v ~/src/github.com/marcusolsson/grafana-plugins:/var/lib/grafana/plugins \
grafana/grafana:8.3.3
You just use the -e flag followe by GF_... using whatever the config label is, followed by =your-value-here
docs here:
I am trying to do the same here. My goal is to configure the grafana.ini file so that I can send email alerts notifications. Where to add you have passe on above, in the console shell of portainer or?
