I am attempting to set up Google sheets, and grafana. It appears everything is working fine on the test in Grafana but no sheet ID is getting populated. Can anyone provide some insight into this?
Hi there - can you share what version of Grafana you’re running and how the instance is hosted? Is it different than your test instance? Could potentially be an API permission issue - be sure to read up on the configuration docs: https://github.com/grafana/google-sheets-datasource/blob/master/src/docs/configuration.md
