Grafana Alloy install on Aix
How to install grafana -alloy in AIX.
AIX isn’t a supported OS, so the answer is no, you can’t install on AIX. Install Grafana Alloy | Grafana Alloy documentation
You could try building Alloy from source (you can download the source from GitHub)… but you’re deep in unsupported territory and very much on your own.
bypass alloy and write directly to Loki using a scripting language ie
