Grafana version : 8.5.1
OS : Redhat Linux -
Alerts -
We have configured Alerts, but the Alerts view always shows as NO DATA -
What happened?
Not sure. -
Trigger an alert to the listed contacts whenever the thresholds are breached. -
Yes -
I am pasting the screenshot. Refer to Screenshot names.
Query Inspector.PNG ---- Shows that Data is present
Alert CONFIG.PNG ---- Shows Alert Configuration
Alert QUERY.PNG ----- Shows Query
Alert Page [NO DATA].PNG — Main Alert Page showing [NO DATA
