Grafana Alerting (Spring-Boot Prometheus metrics) - Send an alert notification per new condition check
I am trying to create alerts using Grafana for Spring Boot metrics scraped from Prometheus. The use-case is to alert for exceptions thrown from each service. I’m using the http_server_requests_seconds_count metric and mentioned below is the breakdown of the PromQL query I’m using to create the graphs.
  • First I’m excluding all the metrics which don’t throw an exception.
http_server_requests_seconds_count{application="my-service-1",exception!="None"}
  • Next I’ve applied the rate() function since the default metric just provides a monotonous value.
rate(http_server_requests_seconds_count{application="my-service-1",exception!="None"}[5m])
  • Then I’ve used the following condition to trigger an alert. (Using max() function as the sum() and the count() functions take the data-points into consideration, which is not my requirement)
WHEN max() OF query(A,5m,now) IS ABOVE 0.02
EVALUATE every 1m FOR 5m
The above setup works fine an sends a notification whenever the alert condition is met. However,I’m facing several problems with this approach.
  1. I need the actual count of exceptions instead of a rate
I’ve tried the following approach to solve this. But, it still gives a monotonous value until a new exception is thrown.
count_over_time(http_server_requests_seconds_count{application="my-service-1",exception!="None"}[5m])
  1. I’m getting a series for each exception and unless the alerting state has gone back to Ok , Grafana will not send a notification for a second time the condition is met from a different series.
I thought maybe if I can get a spike per exception for each series, and the graph stays at 0 for the rest of the time, I can solve this issue. So, I’ve tried reducing the time interval for the rate() function but, it seems like I can reduce it up until 1 minute only. Eventhough it resolves the problem a bit, whenever a second exception comes from another series in between that 1 minute, it won’t send a new notification.
rate(http_server_requests_seconds_count{application="my-service-1",exception!="None"}[1m])
WHEN max() OF query(A,1m,now) IS ABOVE 0.02
EVALUATE every 1m FOR 0m
How can I address the above issues and get Grafana to alert per new exception and also send the count instead of a rate?
(I’m using Grafana v6.5.3)
Appreciate you kind help!
Hi @ErandaEG
You should have a much better chance completing your goal with the new Unified Alerting in Grafana 8, which shipped today. It’s an entirely new alerting platform with much greater power and ease-of-use. And it includes much greater support for variables in alerts
Check it out:
docker run -p 3000:3000 --name=grafana -e "GF_FEATURE_TOGGLES_ENABLE=ngalert" grafana/grafana:8.0.0
Hi @anon70503803! Thank you so much for replying! :blush:
Just a quick question. Seems like this feature is still not publicly available and we have to enable it by adding some changes to grafana.ini file.
  • [panels] enable_alpha; Set to true if you want to test alpha panels that are not yet ready for general usage. Default is false .
enable_alpha: true
  • Setting the ngalert feature toggle enables the new Grafana 8 Alerting system.
ngalert: true
However, I saw the following set of lines in the documentation for FeatureToggles interface (Configure feature toggles | Grafana documentation).
meta property
Signature
meta: boolean;
TypeScript
Remarks
Available only in Grafana Enterprise
ngalert property
Signature
ngalert: boolean;
Is the remark mentioned above belonging to ngalert property, which in turn means that the new alerting feature will be only available for Grafana Enterprise version?
I will get clarity on our temprary use of the FeatureToggle for Unified Alerting, but rest assured:
Unified Alerting is available in Grafana OSS
I believe that the feature toggle is designed to keep the legacy alerting intact until the Unified Alerting platform is a little more battle-tested.
Thank you so much for clarifying @anon70503803! I will use the newest update and try to address my problem with it. :blush:
