The latest version of Grafana Agent (v0.39) embedded custom metrics for MSSQL integration. I tried the below configuration with adding ‘query_config’ section in integrations_config, and then Grafana Agent Service failed to start. If I removed ‘query_config’ section, it worked.
mssql:
enabled: true
connect_string: "sqlserver://<USERNAME>:<PASSWORD>@<HOST>:<PORT>"
query_config:
- metric_name: mssql_deadlocks_total
type: counter
help: 'Number of lock requests that resulted in a deadlock.'
values: [cntr_value]
query: |
SELECT cntr_value FROM sys.dm_os_performance_counters WITH (NOLOCK) WHERE counter_name = 'Number of Deadlocks/sec' AND instance_name = '_Total'
I just followed the doc you posted, adding ‘query_config’ block in the config file, but failed.
can you try something like this:
query_config:
collector_name: mssqlmi_clerk
# Similar to global.min_interval, but applies to the queries defined by this collector only.
#min_interval: 0s
metrics:
# Collected from sys.dm_os_memory_clerks
- metric_name: mssqlmi_clerk_size_kilobytes
type: gauge
help: 'Memory Clerk'
key_labels:
- clerk_type
values: [size_kb]
query_ref: mssqlmi_clerk
queries:
- query_name: mssqlmi_clerk
query: |
SELECT
mc.[type] AS [clerk_type]
,SUM(mc.[pages_kb]) AS [size_kb]
FROM sys.[dm_os_memory_clerks] AS mc WITH (NOLOCK)
GROUP BY
mc.[type]
HAVING
SUM(mc.[pages_kb]) >= 1024
OPTION(RECOMPILE);
I wanted to post here as I was not able to find this information anywhere else. There are two important things to keep in mind for using custom query metrics:
- You may add your metrics to the standard list by copying the original mssql_standard collector block (available here) to a yaml file and appending your entries to the existing list. This new file can then be fetched using a
local.file block assigned to the query_config variable:
prometheus.exporter.mssql "integrations_mssql" {
connection_string = "sqlserver://user:pass@127.0.0.1:1433"
query_config = local.file.mssqlqueries.content
local.file "mssqlqueries" {
filename = "./mssqlqueries.yml"
- Because the
query_config variable only supports a single collector_name and metrics entries, multiple query files (e.g., one for cluster-specific metrics and a separate for custom application metrics) require individual exporter, relabel, scrape, etc blocks for each yaml file:
# Note that this first definition includes the default SQL metrics
# and does not require a local.file definition
discovery.relabel "integrations_mssql" {
targets = prometheus.exporter.mssql.integrations_mssql.targets
rule {
target_label = "job"
replacement = "integrations/mssql"
prometheus.scrape "integrations_mssql" {
targets = discovery.relabel.integrations_mssql.output
job_name = "integrations/mssql"
# Additional SQL metrics defined in yaml files
prometheus.exporter.mssql "integrations_app_sql" {
query_config = local.file.app_sql_queries.content
local.file "app_sql_queries" {
filename = "./mssql_appdb.collector.yml"
discovery.relabel "integrations_app_sql" {
targets = prometheus.exporter.mssql.integrations_app_sql.targets
rule {
prometheus.scrape "integrations_app_sql" {
targets = discovery.relabel.integrations_app_sql.output
@mbergeron
Can you please provide the mssql_appdb.collector.yml or mssqlqueries.yml to check what are the metrics.
The standard queries are documented here: prometheus.exporter.mssql | Grafana Alloy documentation
or in the original SQL collector source here: sql_exporter/documentation/sql_exporter.yml at master · burningalchemist/sql_exporter · GitHub
For creating a custom application SQL metrics entry, or even to gather non-standard SQL metrics, you simply follow that model. For example, collecting AlwaysOn cluster status would look something like this (forum won’t allow me to upload the yaml file)
collector_name: mssql_ao
metrics:
- metric_name: mssql_ao_replica_db_syncstate
type: gauge
help: 'Synchronization state of DB across AO cluster.'
key_labels:
- replica_group_name
- replica_database_name
- replica_server_name
- role
- synchronization_state_desc
values: [synchronization_state]
query: |
SELECT sys.availability_groups.name AS replica_group_name,
sys.dm_hadr_database_replica_cluster_states.database_name AS replica_database_name,
sys.availability_replicas.replica_server_name,
sys.dm_hadr_availability_replica_states.role_desc AS role,
sys.dm_hadr_database_replica_states.synchronization_state_desc,
sys.dm_hadr_database_replica_states.synchronization_state AS synchronization_state
FROM sys.dm_hadr_database_replica_cluster_states
JOIN sys.availability_replicas ON sys.dm_hadr_database_replica_cluster_states.replica_id = sys.availability_replicas.replica_id
JOIN sys.dm_hadr_availability_replica_states ON sys.availability_replicas.replica_id = sys.dm_hadr_availability_replica_states.replica_id
JOIN sys.availability_groups ON sys.availability_replicas.group_id = sys.availability_groups.group_id
JOIN sys.dm_hadr_database_replica_states ON sys.dm_hadr_database_replica_cluster_states.group_database_id = sys.dm_hadr_database_replica_states.group_database_id
AND sys.dm_hadr_database_replica_cluster_states.replica_id = sys.dm_hadr_database_replica_states.replica_id;
and the Alloy config includes a similar set of syntax to ingest and process this:
prometheus.exporter.mssql "integrations_ao_mssql" {
query_config = local.file.ao_queries.content
local.file "ao_queries" {
filename = "./mssql_ao.collector.yml"
Thanks for your respond.
If i create custom yml file without including default standard queries, still will get default metrics or not .
