I am quite new to grafana cloud agent. Need some help on mysql exporter integration.
If I want to add some custom metrics, for example,
select count(*) from information_schema.processlist;
What is the right way to add it into existing mysqld_exporter integration section?
Can I add multiple queries?
mysqld_exporter:
enabled: true
data_source_name: root@(server-a:3306)/
relabel_configs:
- source_labels: [__address__]
target_label: instance
replacement: server-a
Thank you
