First timer here. Please be gentle.
I’m wanting to ingest metrics and logs from my Macbook using Grafana Agent, but getting an HTTP status 405 error in the grafana-agent-err.log file.
Also, when I try to create a new viz, the data panel says No Data for the grafanacloud--logs option.
And Grafana Agent install via brew on MacOS Ventura -
Ingest metrics and logs from my Macbook to Grafana Cloud and build dashboards -
What happened?
Getting 405 error, Method Not Allowed -
Logs and metrics get loaded into my Grafana Cloud instance and I’m able to build dashboards from the New Visualizations panel -
ts=2023-07-03T21:19:36.768705Z caller=client.go:430 level=error component=logs logs_config=integrations component=client host=logs-prod-006.grafana.net msg="final error sending batch" status=405 tenant= error="server returned HTTP status 405 Method Not Allowed (405): "
ts=2023-07-03T21:31:57.180901Z caller=client.go:430 level=error component=logs logs_config=integrations component=client host=logs-prod-006.grafana.net msg="final error sending batch" status=405 tenant= error="server returned HTTP status 405 Method Not Allowed (405): "
ts=2023-07-03T21:44:26.096015Z caller=client.go:430 level=error component=logs logs_config=integrations component=client host=logs-prod-006.grafana.net msg="final error sending batch" status=405 tenant= error="server returned HTTP status 405 Method Not Allowed (405): "
ts=2023-07-03T21:54:53.54712Z caller=client.go:430 level=error component=logs logs_config=integrations component=client host=logs-prod-006.grafana.net msg="final error sending batch" status=405 tenant= error="server returned HTTP status 405 Method Not Allowed (405): "
- Did you follow any online instructions? If so, what is the URL?
macOS integration | Grafana Cloud documentation
