Trying to configure a WebEx contact point to send alerts to. Have successfully created a WebEx space, retrieved Room Id, Created Bot, Created a Contact Point with Bot Token and Room Id.
Verified in WebEx can send with Bot to Room, but Grafana’s Post to https://webexapis.com/v1/messages fails with EOF. Tried test message, tried hardcoded Notification template. Need ideas for what to try next.
Can you share you contact point json
we use webex to send notifications as well
you would need the bot to be in the space
- make sure your room_id and bot_token are correct
other issues i can think of are that the webex might reject when the markdown is not as it expects
- try with default template
