I was using metric lookup in Grafana (4.3) to visualize values of labels. For example to get version of Prometheus itself.
prometheus_build_info{branch="HEAD",goversion="go1.10",instance="localhost:9090",job="prometheus",revision="bc6058c81272a8d938c05e75607371284236aadc",version="2.2.1"}
But in Grafana 5.0, there is no Metric lookup. How should I get the value of version label in this Grafana version (Prometheus does not support returning Strings afaik).
Thanks!
