Label_replace / label_join - use as src_label the label of the metric value
    Grafana v9.1.4
Does anyone knows if its possible to use the label that corresponds to the value of the metric as src_label for the label_replace / label_join functions? And if yes, what is the name of that label? I tried “Value”, but doesn’t seem to work.
label_join(file_stat_size_bytes{fqdn=~“$fqdn”,path=~“/var/log/mylog-[0-9].*.log"}, “new_label”, “|”, “role”, "Value”)
Basically i want to add new label based on the value of another label and the value of the metric.
