Hi. I’m testing new version Grafana 5 and I can’t control the height of the panel. I need to change the height of the panel dynamically depending on the content. Also in my plugin there is a drop-down menu that is hidden behind the panel.
In this video, I use Grafana 4.6 (it work correctly)
In this video, I use Grafana 5-beta (it doesn’t work correctly)
Is there any method in Grafana 5 for changing the height of the panel? Or can you give any advice how to solve this problem?
thanks
