Grafana-5升级到7.4后,访问3000报错
If you’re seeing this Grafana has failed to load its application files
  1. This could be caused by your reverse proxy settings.
  2. If you host grafana under subpath make sure your grafana.ini root_url setting includes subpath. If notusing a reverse proxy make sure to set serve_from_sub_path to true.
  3. If you have a local dev build make sure you build frontend using: yarn start, yarn start:hot, or yarnbuild
  4. Sometimes restarting grafana-server can help
  5. Check if you are using a non-supported browser. For more information, refer to the list of supported browsers.
    原grafana-5可以进行访问,使用yum install -y grafana-7.4.2-1.x86_64.rpm后 服务启动正常 显示升级成功 grafana -v可查看版本7 3000端口启动
    麻烦有遇到过此问题的朋友协助一下,拜托了
Welcome to the community, can you give us more details about your setup ?
Good Luck
