Grafana 10.2.2 - import image in dashboard using file location , username and password
Can i Serve images from NAS to Grafana dashboard 10.2.2 windows OSS build. I need to use file location , user name and password . Please give me a answer
welcome @vidyalekshmipl1
Which visualization is this in? Also what do you mean by import? Do you mean referencing it in a certain dashboard visualization?
In my Grafana dash board , i need to get some images which contain in another file .Also i want to say my file location user name and Password of that file , is it possible.
I think for visualization i can use canvas or text.
So access to this file requires user name and password?
Yes I need it from another file location
some image contain in another file location . I need to import that image by username , password and path is it possible
you can publish your images in an imageshack space (which can help you generate a public url for your image) then using Text plugin, insert the url in an HTML code
insert the url in an HTML code , means how can i insert it in Grafana
