Google cloud monitoring unstable graphs
    Grafana v8.4.4 (fcfb01faeb) on k8s
    I want a graph that looks the same (or very similar) if I refresh after 30 seconds
  • What happened?
    On inital load the graph looks as follows. Threshold is exceeded
Reloading after 30 seconds, the graph looks very different: values are about half as high and are below the threshold
    That the grap looks the same (or very similar)
    Datasource:
MQL query:
fetch l7_lb_rule
| metric ‘logging.googleapis.com/user/test_client_apigroup’
| sum
I found a solution setting the timeshift to “0s/m”
