Grafana version: 10.2
OS: Kubernetes on Ubuntu -
When a user logs out then user should logout without confirmation using RP initiated logout PR #70357. -
I do a login using generic OAuth and then I try to logout after around 5 minutes. -
What happened?
Sometimes I am getting a logout confirmation even if I have passedid_token_hint.
Most of the time it is working as expected.
I think it has something to do with handling ofid_tokenandrefresh_token. -
The logout should happen without confirmation every time ifid_token_hintis provided. -
What I have tried?
As per my understanding in keycloak logs below line is getting hit, Which means theid_tokenused for login and theid_token_hintprovided are different.
I followed grafana latest guide for keycloak integration. -
There are no logs for logout, because there aren’t any, but I found out that the refresh_token was not found even when keycloak sends token everytime when a user is authenticated.
logger=query_data t=2023-12-13T16:38:25.244161279+05:30 level=debug msg="Processing metrics query" query="unsupported value type"
logger=oauthtoken t=2023-12-13T16:38:25.282925348+05:30 level=debug msg="no refresh token available" authmodule=oauth_generic_oauth userid=180
logger=ngalert.scheduler t=2023-12-13T16:38:30.087681296+05:30 level=debug msg="Alert rules fetched" rulesCount=0 foldersCount=0 updatedRules=0
logger=oauth t=2023-12-13T16:38:31.056397025+05:30 level=info msg="state check" queryState=88ba67c7050b9733298d131e340c000ea2dbfeb1c1b9e9754803388e11d1d4a5 cookieState=88ba67c7050b9733298d131e340c000ea2dbfeb1c1b9e9754803388e11d1d4a5
logger=oauth t=2023-12-13T16:38:31.222290849+05:30 level=debug msg="OAuthLogin: got token" expiry="2023-12-14 16:38:31.222180249 +0530 IST m=+95343.864952852" type=Bearer access_token=eyJhbGciOiJSUzI1NiIsInR5cCIgOiAiSldUIiwia2lkIiA6ICJYQURJeFBPUTU5VWxUb21sZ1VrRi1odElsaW1rOGRVY2hRZjQyc05wUmc4In0.<redacated> refresh_token=eyJhbGciOiJIUzI1NiIsInR5cCIgOiAiSldUIiwia2lkIiA6ICIxNDZmMTE3My1jZGYwLTQ4YzMtOGFjOC02Yzg2M2ZmNTAzNTIifQ.<redacated>
logger=oauth.generic_oauth t=2023-12-13T16:38:31.222591083+05:30 level=debug msg="Getting user info"
logger=oauth.generic_oauth t=2023-12-13T16:38:31.222607092+05:30 level=debug msg="Extracting user info from OAuth token"
logger=ngalert.sender.router t=2023-12-13T16:38:33.826392147+05:30 level=debug msg="Finish of admin configuration sync"
logger=oauth t=2023-12-13T16:38:39.422976076+05:30 level=info msg="state check" queryState=2dc9ee6e8f6dcc7a22242f121a91b5405b1ca3d1eca1a850063f61e96750e552 cookieState=2dc9ee6e8f6dcc7a22242f121a91b5405b1ca3d1eca1a850063f61e96750e552
logger=oauth t=2023-12-13T16:38:39.519647239+05:30 level=debug msg="OAuthLogin: got token" expiry="2023-12-14 16:38:39.519540458 +0530 IST m=+95352.162313061" type=Bearer access_token=eyJhbGciOiJSUzI1NiIsInR5cCIgOiAiSldUIiwia2lkIiA6ICJYQURJeFBPUTU5VWxUb21sZ1VrRi1odElsaW1rOGRVY2hRZjQyc05wUmc4In0.<redacated> refresh_token=eyJhbGciOiJIUzI1NiIsInR5cCIgOiAiSldUIiwia2lkIiA6ICIxNDZmMTE3My1jZGYwLTQ4YzMtOGFjOC02Yzg2M2ZmNTAzNTIifQ.<redacated>
logger=oauth.generic_oauth t=2023-12-13T16:38:39.51973212+05:30 level=debug msg="Getting user info"
logger=oauth.generic_oauth t=2023-12-13T16:38:39.519742774+05:30 level=debug msg="Extracting user info from OAuth token"
logger=query_data t=2023-12-13T16:38:41.256772436+05:30 level=debug msg="Processing metrics query" query="unsupported value type"
logger=oauthtoken t=2023-12-13T16:38:41.296327158+05:30 level=debug msg="no refresh token available" authmodule=oauth_generic_oauth userid=180
logger=accesscontrol.service t=2023-12-13T16:38:41.854010617+05:30 level=debug msg="using cached permissions" key=rbac-permissions-1-user-180
logger=query_data t=2023-12-13T16:38:41.854363458+05:30 level=debug msg="Processing metrics query" query="unsupported value type"
- Did you follow any online instructions? If so, what is the URL?
This I used to integrate keycloak.
