Hi there,
I’m looking for an easy way to get data out of heroku, and into Loki (ideally hosted on Grafana Cloud), and I think I need some pointers on how to get data out of Heroku’s logs, and then into Loki, with the rest of logs aggregated from other sources.
Are the services or tools for doing this so far?
(ths is my first post, and the two link limit stopped me posting this. I’ve also dumped this into a gist, with all the links I would have used on github)
I started a twitter thread below with my notes so far, but I can’t be the only person who would find this useful.
So I figured here might be wise to ask before I try doing so myself.
How I think you could do it - 3 ways:
I think there are three main ways, and I’d welcome some pointers before I try implementing them.
- on a cron job
- using a promtail instance on heroku
- using a HTTP API forwarder instance on heroku
the Cronjob approach
One you could conceivably do on a cronjob. You can fetch logs for an app 1500 lines at a time using the CLI with something like this
heroku logs -a your-npp-name -n 1500
If you could persist the timestamp of the last logs, presumably you could send them in batches every N minutes to the Loki push API, using some code that looks a bit like so:
import requests
import json
import datetime
import pytz
host = 'somehost'
curr_datetime = datetime.datetime.now(pytz.timezone(CORRECT_TIMEZONE
curr_datetime = curr_datetime.isoformat('T')
msg = 'On server {host} detected error'.format(host=host)
# push msg log into grafana-loki
url = 'http://host-where-loki-run:3100/api/prom/push'
headers = {
'Content-type': 'application/json'
payload = {
'streams': [
'labels': '{source=\"Name-of-your-source\",job=\"name-of-your-job\", host=\"' + host + '\"}',
'entries': [
'ts': curr_datetime,
'line': '[WARN] ' + msg
payload = json.dumps(payload)
answer = requests.post(url, data=payload, headers=headers)
# end pushing
There’s all kinds of reasons this isn’t ideal, but it might work for quiet services.
the promtail approach
Another option I see would be to run promtail on heroku itself, and have that act as a collector to send logs on to grafana.
You could probably get away with just using a small hobby dyno, as promtail is quite lightweight.
If you’re not that confident with Go though, you might not prefer to do so, and it’s not obvious to me yet how you’d forward along the tags to identify each app.
the HTTP API forwarder
Finally, and lets assume we’re using python as the example above is in that language, you deploy a small python app using something like FastAPI or similar.
You’d then set up a log drain to POST logs to it in batches via HTTP], then have that API push those into Loki using the Push API as I’ve outlined above.
It’s also a fairly simple API to implement. You receive POSTed data, figure out the app that sent it (maybe from the provided log drain token), and then POST almost the same payload to the Loki end point.
Of the three options, I think the third one is the probably the one I’m leaning towards.
Given how popular Heroku is, and how popular Grafana is, I figured this might already be in existence.
Has someone already implemented any of these components?
