GranaLabs (cloud)
Setup Zipkin as a datasource
Run Zipkin in local server and give the HTTP URL as http://localhost:9411/zipkin while configuring the data source in GrafanaLabs
What happened?
Getting HTTP error message
The datasource should be properly configured
Attaching the screenshot
‘HTTP error’ message
Request URL: https://avikchatterji.grafana.net/api/datasources/proxy/38/api/v2/services
HTTP 502
