Grafana v11.3.0 (d9455ff7db) docker oss image on an Almalinux 9.4 system
- What are you trying to achieve?
I’m trying to create a prometheus datasource. I have the prometheus instance in the same docker environment, and i am able to “ping” the prometheus host by name from the grafana instance. But when i try to create and save my datasource for prometheus i get the following error:
422 Unprocessable Entity - There was an error returned querying the Prometheus API.
- How are you trying to achieve it?
I’m clicking on the create data source and giving it a name “prometheus” and server_url of “http://prometheus:9090” and click save.
- What happened?
It creates the datasource, but it’s not valid and i get the following error:
I expected to get the same response as the tutorial docker container:
Successfully queried the Prometheus API.
- Can you copy/paste the configuration(s) that you are having problems with?
my compose file is:
networks:
grafana-net:
volumes:
prometheus-data: {}
grafana-data: {}
services:
prometheus:
image: prom/prometheus:v2.49.0
container_name: prometheus
ports:
- 9090:9090
command:
- '--config.file=/etc/prometheus/prometheus.yml'
- '--storage.agent.path=/prometheus'
- '--web.console.libraries=/etc/prometheus/console_libraries'
- '--web.console.templates=/etc/prometheus/consoles'
- '--web.enable-lifecycle'
- '--enable-feature=agent'
volumes:
- ./config:/etc/prometheus
- prometheus-data:/prometheus
restart: unless-stopped
networks:
- grafana-net
grafana:
image: grafana/grafana-oss:latest
container_name: grafana
ports:
- '3000:3000'
volumes:
- grafana-data:/var/lib/grafana
#password: root123
networks:
- grafana-net
My prometheus config is:
global:
scrape_interval: 15s
scrape_configs:
- job_name: "prometheus"
static_configs:
- targets: ["localhost:9090"]
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
I only have the 422 error in the Grafana UI as described above.
- Did you follow any online instructions? If so, what is the URL?
I’ve followed the docs on installing Grafana via Docker: Run Grafana Docker image | Grafana documentation
i also got the tutorial up and running to compare
