Hello there,
I have some sensors in Prometheus called cca_nodeexporter_sensors. They have the following labels: title, ID, unit. I now want to display in a gauge which is the highest temperature measured in the last hour. So I query the following:
max(max_over_time(wty_nodeexporter_ralf_sensors{title="Temperature"}[1h]))
which results in
So far so good. But now I wish to display the corresponding ID, too, like in the query below:
Is there any chance to display the ID in the gauge or, if its not possible in an extra (text?)panel?
Thanks in advance,
Spider
