Currently I have a MQTT Datasource (it has all connection details) and I have created a panel for this, the panel should able to publish message on MQTT Broker.
Now to do this operation:
- We need to able to call datasource method OR
- Fetch
MQTT Brokerdetails on Panel so I can create a newMQTT clientto do the message publish operation
Currently, I what I am doing on panel side is:
fetch('/api/datasources')API call - filter API output with
data.request.targets > datasource - use the filtered output come as MQTT config
- create MQTT client on panel side as well by using the config
- publish message from there
What would be the best solution to do these all things?
