Hello everyone,
I record in a Grafana database how many updates are not installed on our servers.
I would now like to know in a period of e.g. 30 days on how many days the value was not 0.
I already have a query which gives me a value for each day.
SELECT max("value") FROM "Invoke-IcingaCheckUpdates" WHERE ("hostname"::tag =~ /^$hostname$/ AND "metric"::tag = 'security::ifw_updates::count' AND value > 0 AND time > now() - 30d) GROUP BY time(1d)
I then get the following table:
However, I now lack the idea of how I can count the days, does anyone of you have an idea?
Regards
Marco
Oh sorry, I forgot to add that.
Iām using InfluxDB 1.6.7~rc0 and Grafana in Version v10.4.2.
Use subquery - you already have list of days, so now you can just sum max field (or count max field values) and you will have that count.
how many days = count.
but you have max which is not count. max is biggest value
your issue is more influxql query than grafana
Thanks that was the solution I did not realize that InfluxDB also supports subquerys.
SELECT count(max)
FROM (
SELECT max("value")
WHERE
"value"::field > 0 AND
time > now() - 30d
GROUP BY time(1d)
Thanks
