I use Grafana v5.1.3 (087143285) on my own server (Debian).
Since few releases (I didn’t take time to search for the issue & report it until now), all my metrics queries using tags are not displayed, returning a “Cannot read property ‘templateSrv’ of undefined” error.
I can’t find how to fix this issue. Any idea?
If I limit the query to timestamps where there is no data, I don’t have the error. It’s only when datas are returned.
I use OpenTSDB as source, from OVH.
If I run the command to get the same query from curl, I have the results returned.
I also see them if I check the answer of the query in my browser’s developer tools in network tab.
Yes, it’s the default plugin of Grafana, I’ve not added anything else to default installation.
My configuration is OK (like in the OVH’s docs), it works well if I don’t use tags, but as soon as I use tags, the graph is not created and I get the error.
Again, data points are successfully returned to the request (checked on Chrome developers tools), but graph is not working.
