Grafana v11.4.0 on Windows 11 Pro
I have a geomap with route layer enabled that displays GPS data for different devices. When I switch from a device with GPS data to another device that has no GPS data, I want the previous route to disappear. Currently, the route from the previous device remains visible, which is not the desired behavior.
What happened?
When I select a device with no GPS data, two issues occur:
- The route from the previously selected device remains visible on the map
- The geomap zooms out to show the whole world view
I’ve tried modifying my queries and checking layer configurations, but the issues persist.
Screenshots
Additional information
- Data source: [Your data source]
- Query details: [Brief description of how you’re querying the data]
- Variable setup: [If you’re using variables to select devices]
Any help would be greatly appreciated!
