- Grafana v11.3.0 (d9455ff7db) on windows 11 Pro using Firefox as browser and using the azure data explorer plugin for getting data.
- I have two panels, a geomap with route layer enabled and a time series graph. I want use shared crosshair on both panels.
What happened?
- The shared crosshair on the geomap locks on the end point of the route and it will not move based on the position of the crosshair in the time series graph. I added screenshots to illustrate.
