Geomap panel tooltip font color
how I can change the geomap panel tooltip color i.e after hovering on my points on map I should be able to see the required color inside the point panel.
I dont think there is such a feature? Are you trying to do this for color blindness or other reasons?
as in the given pic , I want the background of the content inside layer1 to be colored , is it possible?
