The visualized panel in the tooltip
Hi! Tell me if it is currently possible, for example, with the help of some plugins, to implement what I attached in the screenshot. That is, visualization of data in a tooltip by a point on the geomap panel? A kind of recursive visualization will work)))
the best you can have now is datalinks in tooltips, pointing to the same dashboard you’re in but with updated variables in the url. Then you can have a separate panel in the same dashboard utilizing these variables. Here’s an example how it’d look like in Mapgl panel plugin https://www.youtube.com/watch?v=zEyyC8Y4CqI you can something like that with geomap
