Hi everyone,
I’m using Grafana version 8.4.1 on Centos.
And I’m trying to use the Geomap panel.
I want to know if there is a way to lookup Cities and not only Countrys ?
Also I tried with the Geohash (xn76y4khb187), but nothing happen
Thanks for your help
It doesn’t make sense to have cities lookup (city names are not unique very often). Let’s say you have city with the name London - where do you place it on the map? There are 29 places around the world called London.
Your geohash is working for me, so I would say you have incorect configuration:
Hi @jangaraj,
Your right about the cities lookup, the idea was to have a location like this : Country/State/City
For the Geohash I don’t understand why it’s not working
I have this metric from prometheus :
{host_id="f********", site="xn76y4khb187"} 15
The table looks correct :
But nothing on the map :
I don’t know. Investigate it: upgrade to the latest stable Grafana version, check errors in the browser console, …
Thanks @jangaraj
It’s working fine with a version 8.3.3
It looks that the geohash is not working with Grafana 8.4.x
