Centos-7 OS with grafana version 8.2.2 -
Timely plotting of certain metrics across the whole world with prometheus -
I was trying to have a metric like this
custom_map_metric{instance=“localhost:6005”, job=“map_config”, latitude=“39.9042”, longitude=“116.4074”, mac=“00:90:81:70:ae:89”}
and i am trying to plot this value whose value falls on the china region as per the latitude and longitude -
What happened?
The plotting of value is happening across end of Africa
In the visualization tab, across the Data layer I am not getting the necessary label of latitude/longitude as per the above image -
Plotting of the data happens in Africa while it has to happen in China
