GDG - Grafana Dash-n-grab tool 0.9.1 released
I meant to do this write up for 0.9.0 but my release script had a bit of a hiccup so here we go with 0.9.1.
GDG (Dash-N-Grab) has just been released. If you’re not familiar with it, it’s a tool that lets you manage various resources that grafana uses (dashboards, connections, folders, etc). It’s similar to grafanactl though it’s a bit more mature and uses some similar concepts (multiple contexts, resources, etc).
GDG can backup your resources and can be used to manage and promote your entities from one environment to another. (I try not to promote it as a backup tool since grafana has a lot more than just the entities I support in the database)
The latest version has better support for alerting and introduced plugin support. contact-points especially has data that I needed to track in version control that contained several sensitive information fields (token, passwords, web-hooks) that warranted the need for some encryption mechanisms. So the plugin system was introduced that allows you to use the plugins I wrote or the ability to easily swap it out with your own implementation.
Community feedback is appreciated. Ask anything you like on this post, join the discussion on github, or come say hi on the grafana slack in #gdg.
Are there any features you wish were available? Something you wish GDG did differently?
(This isn’t exactly a plugin but I could not find a section that would fit this post. If there is a better location to put it feel free to move it to the correct section)
