GCE Compute Engine Monitoring Plugin | Deprecate MQL from Google
I need suggestions/advises how to go further on this?
    Latest Version 9.x and RHEL9.x
    To create a dashboard by using available plugin GCE VM instance Monitoring for getting all VMs count
    which are all under 2 orgs in their sub projects
    Unfortunately i didn’t able to acheive this using
    MQL and i came to know that MQL is deprecated from google.
  • What happened?
    Not able to get the aggregated total number of VMs count
    To list all the VMs count from our orgs and it relevant projects
    fetch gce_instance
    | metric ‘compute.googleapis.com/instance/uptime
    | group_by [metadata.state], count(val())
    N/A
    Nope
