Gauge with MySQL: cannot convert timestamp from db
Hi, after updating Grafana from v7 to v8, my dash visualization stopped working. I matched that after v8 grafana changed time-based query syntax.
My previous query:
SELECT DATE_FORMAT(mydate,"%d %m %Y") AS "time",  sum(energy) AS metric FROM zabbix.consumptions
where host_name="StoykaMain"
group by mydate order by mydate desc
But it shows an error:db convert time column failed: column type "[]*string" is not convertible to time.Time
I’ve tried to resolve and I’ve got this query:
SELECT mydate*1 AS time,  sum(energy) AS metric FROM zabbix.consumptions
And it shows this:
So, how can I set the time correctly and show the graph?
Hi @atonik
A question: What datasource are you using?
I would check out this related thread that discusses the changes to SQL datasources and how to fix a broken query for v8:
I’m using Zabbix MySQL
I’d start here with this note about SQL datasources in Grafana 8:
:+1:
