Gauge panel missing after upgrading fom version 6.5 to 6.7
Hi everyone,
I’ve recently updated my grafana instance from 6.5.2 to 6.7.1 and I can no longer use the Gauge panel to do some of my visualization. The Gauge simply disappeard from the list of available visuallizations and I have no way of finding it. I’ve checked the release notes but couldn’t find any information about it being moved or replaced.
Any ideas how to get it back?
I just tested creating a new dashboard on https://play.grafana.org/ which is Grafana 6.7.1 and the Gauge panel is there:
Can you post a similar screenshot of what it looks like for you?
@daniellee
My servers are not exposed to the internet . I have added the pie-chart and status panel through the rpm pqckages. Its installed successfully in the server but its not populating in the web console. Any idea on this I am also using the grafana 6.7 version.
