Freezes and goes into 100% CPU usage
Every time after 22 days, the server load is set to 100% on the processor and memory, and the machine can work without a network connection. And this happens for 3 days, after which it hangs down and continues to work as if nothing had happened. How do I defeat this?
Loki played on Proxmox mahine:
Processor 8, RAM 22 GB, hard disk 250 GB -SSD
During these 22 days, the disk size increases by only ~15GB.
My configuration:
ingester:
  chunk_block_size: 262144
  chunk_idle_period: 5m
  chunk_target_size: 1572864
  chunk_retain_period: 336h
  chunk_encoding: snappy
  max_chunk_age: 336h
  max_transfer_retries: 0
  lifecycler:
    join_after: 60s
    observe_period: 5s
    address: MY_SERVER
    ring:
      kvstore:
        store: inmemory
      replication_factor: 1
    final_sleep: 0s
common:
  path_prefix: /data/loki
  storage:
    filesystem:
      chunks_directory: /data/loki/chunks
      rules_directory: /data/loki/rules
  ring:
    instance_addr: MY_SERVER
    kvstore:
      store: inmemory
schema_config:
  configs:
      store: boltdb-shipper
      object_store: filesystem
      schema: v11
      index:
        prefix: index_loki_blob
        period: 24h
storage_config:
  index_queries_cache_config:
    memcached:
      batch_size: 100
      parallelism: 100
    memcached_client:
      consistent_hash: true
      host: memcached_host
      service: memcached
  boltdb_shipper:
    active_index_directory: /data/loki/boltdb-shipper-active
    cache_location: /data/loki/boltdb-cache
    cache_ttl: 24h
    shared_store: filesystem
  filesystem:
compactor:
  compaction_interval: 10m
  retention_enabled: true
  retention_delete_delay: 336h
  retention_delete_worker_count: 150
  delete_request_cancel_period: 336h
limits_config:
   max_entries_limit_per_query: 1000
   max_streams_per_user: 100000
   max_chunks_per_query: 200000
   reject_old_samples: true
   ingestion_rate_strategy: local
   ingestion_rate_mb: 200
   ingestion_burst_size_mb: 1500
   retention_period: 336h
   max_query_lookback: 14d
   max_query_series: 100000
   per_stream_rate_limit: "512MB"
   per_stream_rate_limit_burst: "1024MB"
   max_global_streams_per_user: 524288000
   split_queries_by_interval: 30m
query_range:
  align_queries_with_step: true
  cache_results: true
  max_retries: 5
  parallelise_shardable_queries: false
  results_cache:
    cache:
      memcached_client:
        max_idle_conns: 16
        service: memcached
        timeout: 500ms
        update_interval: 5m
chunk_store_config:
  max_look_back_period: 336h
frontend:
  max_outstanding_per_tenant: 1024
  compress_responses: true
ingester_client:
  grpc_client_config:
    max_send_msg_size: 9663676416
query_scheduler:
  max_outstanding_requests_per_tenant: 10000
  grpc_client_config:
table_manager:
  retention_deletes_enabled: true
Kind of hard to answer, there is not a lot of information. Loki exposes various metrics, I would recommend you to capture them and specifically look for memory and heap metrics and see if you can find out where the spike is from.
Unrelated, you should disable table manager if you are using compactor.
tell me if the value is specified correctly: retention_delete_delay: 360h, if my goal is to request logs for a period of 14 days. If I set the value as written in the documentation for 2-3 days, will I then be able to build graphs and request logs for a period of 14 days?
