tofu1
October 4, 2021, 8:19pm
1
my loki crash every few days.
Its the newest binary download file for 64 bit.
The system is a quadcore celeron with 8gb ram.
Is there any way to have detailed logfiles on this crashs?
All i have is the systemctl output:
loki.service - Loki service
Loaded: loaded (/etc/systemd/system/loki.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2021-10-04 00:28:25 CEST; 21h ago
Process: 17068 ExecStart=/usr/local/bin/loki -config.file /etc/loki-local-config.yaml (code=exited, status=2)
Main PID: 17068 (code=exited, status=2)
Okt 04 00:28:24 core1 loki[17068]: google.golang.org/grpc/internal/transport.(*controlBuffer).get(0xc0e35936d0, 0x1, 0x0, 0x0, 0x0, 0x0)
Okt 04 00:28:24 core1 loki[17068]: /src/loki/vendor/google.golang.org/grpc/internal/transport/controlbuf.go:407 +0xff
Okt 04 00:28:24 core1 loki[17068]: google.golang.org/grpc/internal/transport.(*loopyWriter).run(0xc03aef3b60, 0x0, 0x0)
Okt 04 00:28:24 core1 loki[17068]: /src/loki/vendor/google.golang.org/grpc/internal/transport/controlbuf.go:527 +0x1dd
Okt 04 00:28:24 core1 loki[17068]: google.golang.org/grpc/internal/transport.newHTTP2Server.func2(0xc0007fca80)
Okt 04 00:28:24 core1 loki[17068]: /src/loki/vendor/google.golang.org/grpc/internal/transport/http2_server.go:292 +0xd7
Okt 04 00:28:24 core1 loki[17068]: created by google.golang.org/grpc/internal/transport.newHTTP2Server
Okt 04 00:28:24 core1 loki[17068]: /src/loki/vendor/google.golang.org/grpc/internal/transport/http2_server.go:289 +0x1110
Okt 04 00:28:25 core1 systemd[1]: loki.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Okt 04 00:28:25 core1 systemd[1]: loki.service: Failed with result 'exit-code'.
Thanks for your help.
Do you have some kind of monitoring on the ram? like grafana or something, to show. In my experience it happens when the ram gets high because of the ingesters, also I would recommend deploying no in all in one solution but multiple services.
tofu1
October 11, 2021, 11:34am
3
Hello @dror1212 ,
grafana is monitoring the hostsystem.
I see that there was high ram for a while.
But what should be enough ram for loki?
Am i right or not? this is a coding failure?
Normaly the programm has to break the process, not itself.
I am monitoring an overview for OPNSense, input and output counting within an hour.
A top100 ips and ports in block chain. All about max the last day.
One of the ingesters configuration value is
chunk_retain_period
and it’s used to hold some of the data in the ram as some kind of cache, try lowering it and check if it helps
tofu1
October 12, 2021, 5:27am
5
Hi @dror1212 ,
the default for this value seems to be 30s.
I set it to 20s and will recheck.
Thx
it’s 15 minutes by default, you might have looked on the wrong variable.
tofu1
October 12, 2021, 7:58am
7
Its in /etc/loki-local-config.yaml
ingester:
lifecycler:
address: 127.0.0.1
ring:
kvstore:
store: inmemory
replication_factor: 1
final_sleep: 0s
chunk_idle_period: 5m
chunk_retain_period: 20s
max_transfer_retries: 0
ok, so my mistake, I looked at the documentetion when I said the defaults.
It can’t be the problem if it’s that low… can you send your full configuration?
tofu1
October 12, 2021, 12:26pm
9
server:
http_listen_port: 3100
ingester:
lifecycler:
address: 127.0.0.1
ring:
kvstore:
store: inmemory
final_sleep: 0s
schema_config:
configs:
store: boltdb
object_store: filesystem
schema: v11
index:
prefix: index_
period: 168h
storage_config:
boltdb:
directory: /usr/share/loki/index
filesystem:
directory: /usr/share/loki/chunks
limits_config:
enforce_metric_name: false
reject_old_samples: true
chunk_store_config:
max_look_back_period: 0s
table_manager:
retention_deletes_enabled: false
retention_period: 0s
system
Closed
October 12, 2022, 12:27pm
10
