Hello - I’m trying to set up forwarding of alerts to Opsgenie, which works well with the integration and the corresponding Grafana contact point. However, I am struggling with forwarding single alert instances - is this even possible?
Specifically: I am alerting on the health of some severs. To this end, I set up an alert rule which ends up creating about 15 alert instances - all works so far… Now, I want to have a separate alert forwarded to Opsgenie whenever one of those instances is firing. For example, I have 13 of these 15 alert instances showing “Normal” and two are “Firing” - I would want to have two alerts forwarded to Opsgenie. How can one achieve this?
I’m using Grafana v9.2.6
Hello - I’m trying to set up forwarding of alerts to Opsgenie, which works well with the integration and the corresponding Grafana contact point. >>>>>>>>>>>>>I’m even struggling for this , I did integration opsgenie with Grafana but still not getting notifications to opsgenie , Where as test notification am getting , please help on this very crucial blocker for me.
Did we find a solution here ?
Hey we did a trick here , you could remove alias keep it blank in the integration for Create Alert Action, so that instead of creating same alias for all the alert instances under an alert rule it creats a new one each time. Also, disable auto closing of incidents and then enable disabling of resolve messages.
Cons -
Someone has to see the graph and close it manually though
