Grafana Cloud -
I have a state timeline which usesinstance
as the legend next to each bar. Instead, I want to display 2 labels, concatenated like{{site}} ({{instance}})
First I made a Prometheus table querygroup by(site,instance,version) (panasonic_ue_info)
. This returns metrics looking like this:{instance="10.123.106.30", site="ABQ-ATP", version="V2.19"}
Then I use “grouping to matrix” transformation with column=instance, row=time, value=version. This makes a panel like this:
I’ve tried playing with a few other transformations but can’t find any way to do this. The closest I found is to join the labels in the query, but this doesn’t allow any “complex” formatting, like putting parentheses around the IP. label_join(group by(instance, version, site) (panasonic_ue_info), "legend", ",", "site","instance")
