Grafana v10.3.3 (252761264e), Linux -
When my value is null, my graph doesn’t display anything until it receives a value (number).
I would like the curve to stay with the last value :
I don’t know
What happened?
No curve is displayed as long as the value is null -
I use the infinity plugin and request a JSON file
Thank you,
