Grafana 9.0.6 on Debian 11 - What is your datasource?
InfluxDB - What are you trying to achieve?
I am displaying fuel prices in a time series graph. During the night when some of the gas stations are closed the value of the gas price is shown as 0 (zero). Instead of displaying the zero value, I’d like to see the last value above 0 instead. - How are you trying to achieve it?
not sure, maybe a transform that changes to last value if actual value is 0? - What happened?
n/a - What did you expect to happen?
Instead of displaying the zero value, I’d like to see the last value above 0 instead. - Can you copy/paste the configuration(s) that you are having problems with?
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
no errors - Did you follow any online instructions? If so, what is the URL?
did some googling, didn’t find what I needed
Thanks in advance
Cheers
