foldersFromFilesStructurs in provisioning is ignored
  • 11.4.0 onPrem, Windows
Provision Dashboard with folder-structure from Windows
The same structure of folders in Grafana like in Windows.
apiVersion: 1
providers:
  • name: ‘XXXX-Dashboards’
    orgId: 1
    folder: ‘’
    folderUid: ‘’
    type: file
    disableDeletion: false
    updateIntervalSeconds: 10
    allowUiUpdates: false
    options:
    path: e:/Apps/Grafana/grafana/XXXX-dashboards
    foldersFromFilesStructure: true
It’s all done like in the docu. And it worked in the past for three folders:
But if I add a new folder, this folder will be added below root, not in the structure:
I expect this folder where the “AIX Server”- folder is.
And this is the structure in Windows, where the *.jsons are …:
How could I solve this?
Is this a bug or a miss-configuration?
Is something else, what to be set?
I checked the jsons. They are fine.
Thanks a lot.
Regards
Jürgen
