I have a setup where fluent-bit sends logs to Loki which is a data source for Grafana. I get logs for every other service/pod in my data pipeline except for Grafana. The only way I can see those logs is executing into the pod and looking at the files manually, so I can confirm there are logs. Did I miss something in the Grafana/Loki configuration to enable Grafana logs maybe?
