Hi all
We are currently having some problems with the RPM-based distributions (e.g. RedHat, Fedora, CentOS, SUSE, etc.)
If you try to update Grafana to a newer version, you may get the message e.g.
Package grafana-10.1.0-1.x86_64.rpm is not signed
And then the update fails
Luckily, this is a known issue as already reported here:
The Packaging team is already working on the Fix and will provide an update ASAP
Thank you for your patience
This is now fixed.
See the GitHub issue link for details.
