10.4.6 Centos 8 -
Upgrade to 10.4.7 -
sudo yum install -y https://dl.grafana.com/enterprise/release/grafana-enterprise-10.4.7-1.x86_64.rpm -
What happened?
Exécution de la transaction
Préparation : 1/1
Exécution du scriptlet: grafana-enterprise-10.4.7-1.x86_64 1/1
Mise à jour de : grafana-enterprise-10.4.7-1.x86_64 1/2
erreur : failed to open dir data of /usr/share/grafana/plugins-bundled/internal/input-datasource/node_modules/@grafana/data/: Le fichier existe
Error unpacking rpm package grafana-enterprise-10.4.7-1.x86_64
Vérification de : grafana-enterprise-10.4.7-1.x86_64 1/2
Vérification de : grafana-enterprise-10.4.6-1.x86_64 2/2
Échec:
grafana-enterprise-10.4.6-1.x86_64 grafana-enterprise-10.4.7-1.x86_64
Erreur : La transaction a échoué
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
logger=server t=2024-08-16T21:03:28.4712467+02:00 level=info msg=“Shutdown started” reason=“System signal: terminated”
logger=ticker t=2024-08-16T21:03:28.4712981+02:00 level=info msg=stopped last_tick=2024-08-16T21:03:20+02:00
logger=tracing t=2024-08-16T21:03:28.4713723+02:00 level=info msg=“Closing tracing”
logger=grafana-apiserver t=2024-08-16T21:03:28.4720603+02:00 level=info msg=“StorageObjectCountTracker pruner is exiting”
logger=settings t=2024-08-16T21:04:05.6427343+02:00 level=info msg=“Starting Grafana” version=10.4.6 commit=7639d966b5172e74ec89bbf3d356faef4c26a55a branch=HEAD compiled=2024-08-16T21:04:05+02:00
logger=settings t=2024-08-16T21:04:05.6433529+02:00 level=info msg=“Config loaded from” file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2024-08-16T21:04:05.6433759+02:00 level=info msg=“Config loaded from” file=/etc/grafana/grafana.ini
logger=settings t=2024-08-16T21:04:05.6433855+02:00 level=info msg=“Config overridden from command line” arg=“default.paths.data=/var/lib/grafana”
logger=settings t=2024-08-16T21:04:05.6433931+02:00 level=info msg=“Config overridden from command line” arg=“default.paths.logs=/var/log/grafana”
logger=settings t=2024-08-16T21:04:05.6434006+02:00 level=info msg=“Config overridden from command line” arg=“default.paths.plugins=/var/lib/grafana/plugins”
logger=settings t=2024-08-16T21:04:05.6434088+02:00 level=info msg=“Config overridden from command line” arg=“default.paths.provisioning=/etc/grafana/provisioning”
logger=settings t=2024-08-16T21:04:05.6434195+02:00 level=info msg=Target target=[all]
logger=settings t=2024-08-16T21:04:05.6434338+02:00 level=info msg=“Path Home” path=/usr/share/grafana
logger=settings t=2024-08-16T21:04:05.6434468+02:00 level=info msg=“Path Data” path=/var/lib/grafana
logger=settings t=2024-08-16T21:04:05.6434544+02:00 level=info msg=“Path Logs” path=/var/log/grafana
logger=settings t=2024-08-16T21:04:05.6434618+02:00 level=info msg=“Path Plugins” path=/var/lib/grafana/plugins
logger=settings t=2024-08-16T21:04:05.6434692+02:00 level=info msg=“Path Provisioning” path=/etc/grafana/provisioning
logger=settings t=2024-08-16T21:04:05.6434765+02:00 level=info msg=“App mode production”
logger=sqlstore t=2024-08-16T21:04:05.6440726+02:00 level=info msg=“Connecting to DB” dbtype=sqlite3
logger=migrator t=2024-08-16T21:04:05.6451025+02:00 level=info msg=“Starting DB migrations”
logger=migrator t=2024-08-16T21:04:05.6699746+02:00 level=info msg=“migrations completed” performed=0 skipped=646 duration=665µs
logger=licensing t=2024-08-16T21:04:05.6712944+02:00 level=info msg=“Validated license token” appURL=http://localhost:3000/ source=disk status=NotFound
logger=secrets t=2024-08-16T21:04:05.675184+02:00 level=info msg=“Envelope encryption state” enabled=true currentprovider=secretKey.v1
logger=renderer.manager t=2024-08-16T21:04:05.6900636+02:00 level=error msg=“Failed to get renderer plugin sources” error=“failed to open plugins path”
logger=caching.service t=2024-08-16T21:04:05.6910959+02:00 level=info msg=“Caching service is disabled”
logger=plugin.store t=2024-08-16T21:04:05.6925504+02:00 level=info msg=“Loading plugins…”
logger=plugin.sources t=2024-08-16T21:04:05.6925989+02:00 level=error msg=“Failed to load external plugins” error=“failed to open plugins path”
logger=plugins.registration t=2024-08-16T21:04:05.8086591+02:00 level=info msg=“Plugin registered” pluginId=input
logger=plugin.store t=2024-08-16T21:04:05.8087173+02:00 level=info msg=“Plugins loaded” count=56 duration=116.1668ms
logger=query_data t=2024-08-16T21:04:05.8169439+02:00 level=info msg=“Query Service initialization”
logger=live.push_http t=2024-08-16T21:04:05.8246043+02:00 level=info msg=“Live Push Gateway initialization”
logger=ngalert.migration t=2024-08-16T21:04:05.8312221+02:00 level=info msg=Starting
logger=ngalert.state.manager t=2024-08-16T21:04:05.8472921+02:00 level=info msg=“Running in alternative execution of Error/NoData mode”
logger=infra.usagestats.collector t=2024-08-16T21:04:05.8511407+02:00 level=info msg=“registering usage stat providers” usageStatsProvidersLen=4
logger=server t=2024-08-16T21:04:05.8538068+02:00 level=info msg=“Writing PID file” path=/var/run/grafana/grafana-server.pid pid=2034
logger=provisioning.alerting t=2024-08-16T21:04:05.8562056+02:00 level=info msg=“starting to provision alerting”
logger=provisioning.alerting t=2024-08-16T21:04:05.8562554+02:00 level=info msg=“finished to provision alerting”
logger=report t=2024-08-16T21:04:05.856506+02:00 level=warn msg=“Scheduling and sending of reports disabled, SMTP is not configured and enabled. Configure SMTP to enable.”
logger=ngalert.state.manager t=2024-08-16T21:04:05.863045+02:00 level=info msg=“Warming state cache for startup”
logger=renderer.manager t=2024-08-16T21:04:05.8641685+02:00 level=error msg=“Failed to get renderer plugin sources” error=“failed to open plugins path”
logger=grafanaStorageLogger t=2024-08-16T21:04:05.8655675+02:00 level=info msg=“Storage starting”
logger=ngalert.multiorg.alertmanager t=2024-08-16T21:04:05.8682387+02:00 level=info msg=“Starting MultiOrg Alertmanager”
logger=http.server t=2024-08-16T21:04:05.8710023+02:00 level=info msg=“HTTP Server Listen” address=[::]:3000 protocol=http subUrl= socket=
logger=plugins.update.checker t=2024-08-16T21:04:05.9463003+02:00 level=info msg=“Update check succeeded” duration=81.4718ms
logger=grafana.update.checker t=2024-08-16T21:04:05.9465825+02:00 level=info msg=“Update check succeeded” duration=86.953ms
logger=provisioning.dashboard t=2024-08-16T21:04:05.9622837+02:00 level=info msg=“starting to provision dashboards”
logger=provisioning.dashboard t=2024-08-16T21:04:05.9623299+02:00 level=info msg=“finished to provision dashboards”
logger=ngalert.state.manager t=2024-08-16T21:04:05.96586+02:00 level=info msg=“State cache has been initialized” states=0 duration=102.8124ms
logger=ngalert.scheduler t=2024-08-16T21:04:05.9659366+02:00 level=info msg=“Starting scheduler” tickInterval=10s maxAttempts=1
logger=ticker t=2024-08-16T21:04:05.9659977+02:00 level=info msg=starting first_tick=2024-08-16T21:04:10+02:00
logger=grafana-apiserver t=2024-08-16T21:04:06.4289836+02:00 level=info msg=“Adding GroupVersion playlist.grafana.app v0alpha1 to ResourceManager”
logger=grafana-apiserver t=2024-08-16T21:04:06.4294374+02:00 level=info msg=“Adding GroupVersion featuretoggle.grafana.app v0alpha1 to ResourceManager”
logger=context userId=1 orgId=1 uname=admin t=2024-08-16T21:04:13.7992907+02:00 level=info msg=“Request Completed” method=GET path=/api/live/ws status=-1 remote_addr=192.168.1.20 time_ms=30 duration=30.8503ms size=0 referer= handler=/api/live/ws status_source=server
logger=context userId=1 orgId=1 uname=admin t=2024-08-16T21:04:23.2312185+02:00 level=info msg=“Request Completed” method=GET path=/api/live/ws status=-1 remote_addr=192.168.1.20 time_ms=2 duration=2.2146ms size=0 referer= handler=/api/live/ws status_source=server
logger=server t=2024-08-16T21:04:36.621092+02:00 level=info msg=“Shutdown started” reason=“System signal: terminated”
logger=tracing t=2024-08-16T21:04:36.6217908+02:00 level=info msg=“Closing tracing”
logger=ticker t=2024-08-16T21:04:36.6241613+02:00 level=info msg=stopped last_tick=2024-08-16T21:04:30+02:00
logger=grafana-apiserver t=2024-08-16T21:04:36.6249963+02:00 level=info msg=“StorageObjectCountTracker pruner is exiting”
