Grafana Version 11.2.1
OS : CentOS 7.9
Update 11.2.1 with security fix
yum update grafana-enterprise-11.2.1+security~01-1.x86_64.rpm
What happened?
Error with this message
rpmlib(CaretInVersions) <= 4.15.0-1 is needed for grafana-enterprise-11.2.1^security_01-1.x86_64
Update OK
Okay, this is basically because you are using CentOS 7. Is there a reason you don’t upgrade it to 8 or 9?
I have an entreprise template with CentOS 7.9.
I wait for a next version with security fix embarqued
