Find all dashboards using certain datasource before removing datasource
    9.4.3
    Find all dashboards using a certain datasource before deleting datasource. We are migrating to a new source for time series and would like to find all dashboards using the old datasource.
    Via the api for datasources or dashboards and the GUI if possible.
  • What happened?
    No api exist that I can find to search this.
    I way to easily see all dashboards using a datasource before I delete the datasource.
    n/a
    n/a
    n/a
Looking for a UI or API way to find all dashboards using a certain datasource.
GitHub - panodata/grafana-wtf: Grep through all Grafana entities in the spirit of git-wtf. is the right tool to help you. But be creative and slightly modify your requirements - e.g. which dashboards contains this particular datasource uid or datasource name
Thanks. I wrote a narrow version of that using RUST that just pulls out the panel datasources per dashboard. Was a great resource.
