Grafana v11.0.0 (277ef258d4) / OS : Windows 10 Pro
- What are you trying to achieve?
Filtering words of a string to convert it to numbers so as to set tresholds and have an icon change its color when im getting an error in that string
Im trying to use the “Value mapping” tab in order to exchange that string that im reciving to a number
What happened?
I found that the string im using comes with date and time information that changes every second so I need a way to filter key words that if are not found in my string I can change it to a certain number and then make that number give an exact color on the icon im using to show if its working
Find a way to filter
No -
No
