using Datasource InfluxDB, the return value is a text:
2021-01-29 17:40:11 Warning
How to change the color for. OK=Green, Warning=Yellow, Critical=Red?
regards!
Valdemar
Use value mappings then adjust your threshold to match the colors.
Good Luck
thanks wlargou,
understood that still not possible to receive a text from datasource and convert to a number and adjust threshold to match the colors and get back the text.
Warning → 1 → Warning (yellow)
I will keep this way, all blue.
