Hello, It would be possible to filter annotations by panel?
For example, I have a “maquina” variable multi-value:
With repeated panel I could do:
But It shows the same annotations for all panels.
I tried to change the annotations query, it works but It does not take into account the value of repeated panel:
SELECT UNIX_TIMESTAMP(t.fecha_creacion) as time_sec, t.descripcion as text, $maquina as tags FROM trabajo t JOIN trabajotipo tp ON tp.id=trabajos_tipo_id AND tp.nombre='Averia' join proyectomaquina pm ON pm.id=t.proyecto_maquina_id join maquina m ON m.id=pm.maquina_id AND m.id IN ($maquina) WHERE $__timeFilter(fecha_creacion) ORDER BY fecha_creacion ASC
Now, it uses this value instead on use a single value when pannel has a repeated configuration:
$machine =‘43’,‘23’,‘25’
Thank you
