Grafana 8.4.6 -
I want to create Dashboards that display different pannels with the live alerts, depending of Severity and Namespace. I want fixed pannel for Severity (one pannel per severity), and dynamic pannel for Namespace. -
For Warning alerts, I create a Alert list Pannel with filter Alert instance label equals to variable “$namespace” and “warning” -
What happened?
No filtering is done (aka all alerts are visible no matter what are their namespace) when choosing a specific namespace out of my variable. However, if I hardcode the filter to namespace=“mynamespace”, then filtering work, and only alerts taken with namespace “mynamespace” are visible.
Note that if I use the same variablefor other pannels in the same Dashboard, there is no problem.
I expect the filtering on label in a Alert Lists to work on variable.
- Can you copy/paste the configuration(s) that you are having problems with?
Templating:
"templating": {
"list": [
"current": {
"selected": false,
"text": "All",
"value": "$__all"
"definition": "label_values(ALERTS, severity)",
"hide": 0,
"includeAll": true,
"label": "severity",
"multi": false,
"name": "severity",
"options": [],
"query": {
"query": "label_values(ALERTS, severity)",
"refId": "StandardVariableQuery"
"refresh": 1,
"regex": "",
"skipUrlSync": false,
"sort": 0,
"type": "query"
"current": {
"selected": false,
"text": "All",
"value": "$__all"
"definition": "label_values(ALERTS, equipe)",
"hide": 0,
"includeAll": true,
"multi": false,
"name": "equipe",
"options": [],
"query": {
"query": "label_values(ALERTS, equipe)",
"refresh": 1,
"regex": "",
"sort": 0,
"type": "query"
"current": {
"selected": true,
"text": "acceptation",
"value": "acceptation"
"definition": "label_values(ALERTS, namespace)",
"hide": 0,
"includeAll": true,
"multi": false,
"name": "namespace",
"options": [],
"query": {
"query": "label_values(ALERTS, namespace)",
"refresh": 1,
"regex": "",
"sort": 0,
"type": "query"
Alert pannel not working as expected:
Important line is
"alertInstanceLabelFilter": "severity=\"warning\",namespace=\"$namespace\"",
"gridPos": {
"h": 14,
"w": 12,
"x": 12,
"y": 10
"id": 4,
"options": {
"alertName": "",
"dashboardAlerts": false,
"groupBy": [],
"groupMode": "default",
"maxItems": 20,
"sortOrder": 1,
"stateFilter": {
"error": true,
"firing": true,
"inactive": false,
"noData": false,
"normal": false,
"pending": true
"title": "Alertes Warning",
"type": "alertlist"
Alert pannel working as expected (difference is this line
"alertInstanceLabelFilter": "severity=\"warning\",namespace=\"mynamespace\"",
"gridPos": {
"h": 14,
"w": 12,
"x": 12,
"y": 10
"id": 4,
"options": {
"alertName": "",
"groupBy": [],
"maxItems": 20,
"sortOrder": 1,
"stateFilter": {
"error": true,
"firing": true,
"inactive": false,
"noData": false,
"normal": false,
"pending": true
"type": "alertlist"
Pannel with Namespace variable working correctly:
"gridPos": {
"h": 8,
"w": 11,
"x": 0,
"y": 1
"id": 14,
"options": {
"legend": {
"calcs": [],
"displayMode": "list",
"placement": "bottom"
"tooltip": {
"mode": "single",
"sort": "none"
"targets": [
"datasource": {
"type": "prometheus",
"uid": "prometheus"
"exemplar": true,
"expr": "SUM(ALERTS{severity=~\"$severity\", namespace=~\"$namespace\"})",
"interval": "",
"legendFormat": "",
"refId": "A"
"datasource": {
"uid": "prometheus"
"exemplar": true,
"expr": "",
"hide": false,
"interval": "",
"legendFormat": "",
"refId": "B"
"title": "Total alertes",
"type": "timeseries"
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No error is displayed
- Did you follow any online instructions? If so, what is the URL?
No
